Date/Time: Tue, 14 Jan 2025 23:57:50 +0000
Volume - Colored Based on Bars Closes bug
View Count: 1060
[2017-06-01 08:13:23] |
User497810 - Posts: 1 |
There is a bug with this indicator. I have attached a screenshot where you can see that the 2nd bar after the crosshair is green but the corresponding volume bar is red. I have seen this on quite a few other occasions. This can get very confusing.
gbpjpy.png / V - Attached On 2017-06-01 08:12:31 UTC - Size: 22.45 KB - 254 views Attachment Deleted. |
[2017-06-01 19:10:34] |
There is no bug. It works correctly according to the documentation: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=312#Volume_Colored_Based_on_Bar_Closes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
