Date/Time: Sun, 27 Sep 2026 18:58:49 +0000
Unable to connect to OEC prod and sim data feed
View Count: 1440
[2017-06-01 02:02:25]
User135107 - Posts: 1
I have been able to connect to the production server before.
I am able to connect to the data feed through my broker's platform without issue.
Here is the log:
Reading Internal Order ID file. | 2017-05-31 20:35:57
Reading Trade Orders file. | 2017-05-31 20:35:57
Reading Trade Positions file. | 2017-05-31 20:35:57
Listening on UDP port 22903. | 2017-05-31 20:35:57
Software version: 1564 | 2017-05-31 20:35:57
Uses New Spreadsheets | 2017-05-31 20:35:57
Usage end date: 2017-06-20 | 2017-05-31 20:35:57
Enabled for: Advanced Features. | 2017-05-31 20:35:57
Enabled for: Advanced Features 2. | 2017-05-31 20:35:57
Enabled for: Sierra Chart Historical Data Service. | 2017-05-31 20:35:57
Allow Support for Sierra Chart Data Feeds is enabled. | 2017-05-31 20:35:57
Current selected Data/Trading service: GAIN Capital/OEC | 2017-05-31 20:35:57
Chart Update Interval: 500 | 2017-05-31 20:35:57
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-05-31 20:35:57
2017-05-31 20:36:00 Local computer time | 2017-05-31 20:35:57
2017-06-01 01:36:00 Local computer time in UTC | 2017-05-31 20:35:57
2017-05-31 20:36:00 Local computer time in SC Time Zone | 2017-05-31 20:35:57
2017-06-01 01:36:07 Server time in UTC | 2017-05-31 20:35:57
Local computer UTC time and Server UTC time difference: 7 seconds. | 2017-05-31 20:35:57
Program path: C:\SierraChart\ | 2017-05-31 20:35:57
Data Files path: C:\SierraChart\Data\ | 2017-05-31 20:35:57
OS Version Number: 6.2 | 2017-05-31 20:35:57
Locale Setting: C | 2017-05-31 20:35:57
Created the DTC Protocol server. | 2017-05-31 20:35:57
DTC Protocol Server listening on port 11099. | 2017-05-31 20:35:57
Created the DTC Protocol historical data server. | 2017-05-31 20:35:57
HD Server Manager | Listening on port 11098 | 2017-05-31 20:35:57
Checking for new symbol settings for service code oec | 2017-05-31 20:35:57
HTTPS connection to www.sierrachart.com:443 (3) | Creating socket. Using TLS 1.2. | 2017-05-31 20:35:57
HTTPS connection to www.sierrachart.com:443 (3) | Connecting to IP: 5.9.8.236. | 2017-05-31 20:35:57
Symbol settings are up-to-date for oec | 2017-05-31 20:36:01
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-31 20:36:06
GAIN Capital FIX Trading socket (4) | Creating socket. Using TLS 1.2. | 2017-05-31 20:36:06
GAIN Capital FIX Trading socket (4) | Connecting to IP: 64.94.37.222. | 2017-05-31 20:36:06
GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-31 20:36:06
GAIN Capital FIX Trading socket (4) | Socket gracefully closed by remote side. | 2017-05-31 20:36:06
GAIN Capital FIX Trading socket (4) | Received socket Close event | 2017-05-31 20:36:06
GAIN Capital FIX Trading socket (4) | Initiating close of socket by core. | 2017-05-31 20:36:06
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2017-05-31 20:36:06
GAIN Capital FIX Trading socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-31 20:36:06
GAIN Capital FIX Trading socket (4) | Closed. | 2017-05-31 20:36:06
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-31 20:36:06
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-31 20:36:06
GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-31 20:36:06
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-31 20:36:06
GAIN Capital/OEC | Disconnected. | 2017-05-31 20:36:06
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-31 20:36:06
HTTPS connection to www.sierrachart.com:443 (3) | Socket gracefully closed by remote side. | 2017-05-31 20:36:06
HTTPS connection to www.sierrachart.com:443 (3) | Received socket Close event | 2017-05-31 20:36:06
HTTPS connection to www.sierrachart.com:443 (3) | Initiating close of socket by core. | 2017-05-31 20:36:06
HTTPS connection to www.sierrachart.com:443 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-31 20:36:06
HTTPS connection to www.sierrachart.com:443 (3) | Closed. | 2017-05-31 20:36:06
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-31 20:36:09
GAIN Capital FIX Trading socket (5) | Creating socket. Using TLS 1.2. | 2017-05-31 20:36:09
GAIN Capital FIX Trading socket (5) | Connecting to IP: 64.94.37.222. | 2017-05-31 20:36:09
GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-31 20:36:09
GAIN Capital FIX Trading socket (5) | Socket gracefully closed by remote side. | 2017-05-31 20:36:09
GAIN Capital FIX Trading socket (5) | Received socket Close event | 2017-05-31 20:36:09
GAIN Capital FIX Trading socket (5) | Initiating close of socket by core. | 2017-05-31 20:36:09
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2017-05-31 20:36:09
GAIN Capital FIX Trading socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-31 20:36:09
GAIN Capital FIX Trading socket (5) | Closed. | 2017-05-31 20:36:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-31 20:36:09
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-31 20:36:09
GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-31 20:36:09
GAIN Capital/OEC | Disconnected. | 2017-05-31 20:36:09
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-31 20:36:09
nect' to prevent further connection attempts. | 2017-05-31 20:47:39
[2017-06-01 02:47:21]
These are the relevant messages:
Refer to:
https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#ConnectionProblem
