Date/Time: Tue, 14 Jan 2025 23:46:41 +0000
Session time not showing up correctly
View Count: 612
[2017-05-31 19:32:45] |
User84163 - Posts: 17 |
File attached.
IMG_2759.JPG / V - Attached On 2017-05-31 19:32:09 UTC - Size: 2.16 MB - 265 views |
[2017-05-31 19:42:12] |
Refer to: Notice: Windows 10 Update Causes Date/Time Controls to Not Display Properly Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
