Date/Time: Tue, 14 Jan 2025 23:59:56 +0000
interactive scale question
View Count: 740
[2017-05-31 18:08:28] |
4646ed - Posts: 230 |
Is it possible to apply different interactive scale settings to main chart vs region 2 vs region 3 etc . For example have region 1 be interactive scale = range, range = automatic, then have region 2 Interactive scale = locked, range = user defined, then have region 3 interactive scale = move, etc or some variation therein? If not, it would certainly be useful. I often have to fiddle round with one region's settings, then go do something else with another region, then have to change settings back and forth. |
[2017-05-31 19:06:24] |
Each Chart Region does have its own Scale Settings but the Interactive Scale setting Range/Move is for the entire chart. We definitely do not expect to change this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-31 19:06:39
[2017-05-31 19:09:57] |
too bad
