Date/Time: Tue, 14 Jan 2025 23:43:32 +0000
Did the Numbers Bars Study change?
View Count: 803
[2017-05-31 16:38:04] |
mike327 - Posts: 10 |
I use the VbP portion of the numbers bars study. I upgraded to 1564 today. It seems new text coloring options were added as settings at the end of the settings list. Anyhow, I now get black VbP price levels where I never used to get them. Any idea what would cause that? I don't know what they mean or do not mean. Thanks, Mike |
[2017-05-31 17:42:39] |
There have been changes but we need to understand this problem more clearly. Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image We may need to get a Chartbook with this single chart in order to understand what the problem is. Here are instructions to do that: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-31 18:18:38] |
Please find attached a single chart/single study chartbook illustrating the VbP issue as described above. If you would like, a friend of mine has not updated his SC version and is running the same chartbook. I could get a before and after pic for you. Thanks |
NQ NumBars Issue.cht - Attached On 2017-05-31 18:18:32 UTC - Size: 31.3 KB - 306 views |
[2017-06-01 03:52:10] |
We now understand why this problem is happening and it is resolved. Update Sierra Chart again with Help >> Download Prerelease. The version is the same but there is a new revision.
