Date/Time: Tue, 14 Jan 2025 23:35:53 +0000
data for ger30
View Count: 1279
[2017-05-31 15:45:11]
Martino - Posts: 6
hello,
would you please check data feed for number bars for ger30, I have been getting unrecognizable numbers ....other instruments are ok.
thanks
martin
[2017-05-31 16:47:33]
Provide an image of the chart or Trade DOM, by following these instructions:
[2017-06-01 12:33:33]
Martino - Posts: 6
http://www.sierrachart.com/image.php?Image=1496320260718.png
[2017-06-01 17:16:41]
You need to set the Tick Size for this symbol to 1. Refer to:
http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TickSize
[2017-06-01 20:06:05]
Martino - Posts: 6
http://www.sierrachart.com/image.php?Image=1496346873409.png
another chart es ..the same problem ,any advice ?
previous helped for ger30.
thanks
[2017-06-01 20:19:27]
You should not be modifying the Tick Size for these symbols.
The ES futures contract requires a Tick Size of .25. The Volume at Price Multiplier needs to be 1.
