Date/Time: Wed, 15 Jan 2025 15:18:39 +0000
[FEATURE REQ] Could you add new Exten POC option in VbP study?
View Count: 1279
[2017-05-31 14:48:25] |
maxima120 - Posts: 144 |
I would like to be able to extend all POCs on the chart, regardless what day they at. From the POC beginning to the right edge of the chart.
[2017-07-02 19:25:38] |
nobody interested?
[2017-07-02 20:48:37] |
The only thing that is supported is to extend to the end of the window (End of Window) but that is only going to be for the Volume Profiles which are visible.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-03 00:41:58
[2017-07-02 20:50:51] |
Yes I know. I was hoping you may want to add this in future
[2017-07-03 10:46:29] |
user8888 - Posts: 159 |
+1
[2017-07-15 21:22:32] |
I have seen "extend until future intersection" option. but it breaks the line even if any volume has been traded at that price on later days. Thank you. that is good progress. Would it be too difficult to add support for not breaking this line (unless its value exactly the same as another POC before or after). so the idea is to see all POCs of the chart VaPs. always. that would be great help! |
