Date/Time: Wed, 15 Jan 2025 00:13:19 +0000
taking too long to load data
View Count: 1012
[2017-05-31 14:40:58] |
User523839 - Posts: 8 |
hi my sierra chart takes a very long time to load when I start my chartbook as I have about 8 charts open with all of the containing tick level data of 1000 days. is there a way to download some of this data so that i don't have to wait so long for it to load everytime i start it up?
[2017-05-31 15:34:49] |
Refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often All of the data is already downloaded. There is nothing special to do for that. You really need to get a faster computer and use a Solid State Drive. Also you should disable any antivirus software you may be using. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-31 15:34:58
