Date/Time: Sat, 11 Jan 2025 04:54:51 +0000
[User Discussion] - supply and demand
View Count: 11804
[2013-09-23 03:37:14]
GaryD - Posts: 61
attached edit files
[2013-09-23 03:38:07]
GaryD - Posts: 61
Sorry, something strange is happening and may be causing double posts / attachments
[2013-09-23 13:08:11]
crazybears - Posts: 314
Hi
code provided by phaedonk work, i mean with notepad++ can be open , i dont' know metatrader and its language but at first look seems take a Low/High ,usign fibo , and maybe up to 3 bars after the low/high taken .
would be better post more screenshot and some explanation of what the indicator try to display.
take a look under Add Custom Study ->User contribuited studies->zig zag High/low trendlines.
could be a good point to sart developing a similar indicator.
[2018-02-03 18:57:50]
Giamsterdam - Posts: 33
Did someone fix the Inidcator? or even a simple rectangle extender?
[2018-02-03 20:27:49]
User700756 - Posts: 16
Here is one that was developed by Beacon Commodity Trading - https://beaconcommoditytrading.com/documentation?blogpost=multi-time-frame-dynamic-support-and-resistance-b873329f7166
