Date/Time: Wed, 15 Jan 2025 00:11:54 +0000
1307 won't update
View Count: 594
[2017-05-31 14:24:00] |
auggie - Posts: 45 |
Hi, I'm using ver 1307. When I to download the current version (old spreadsheets) it just downloads and installs 1307 again?
[2017-05-31 18:43:44] |
If you need to use Old Spreadsheets you cannot update beyond 1307. Although you could manually install 1310 but that is as high as you can go for Old Spreadsheet support.
