Date/Time: Wed, 15 Jan 2025 00:13:19 +0000
Go To Date and Time stopped functioning post Version 1563 Update
View Count: 696
[2017-05-31 06:31:08] |
User186889 - Posts: 53 |
The Go To Date and Time function (CTRL+ALT+G) has stopped working correctly after I installed the update V 1563 (Installed 31 May 17). It brings up the box but there are random characters in it and no way to use the function Regards, Mark B |
[2017-05-31 06:32:30] |
Refer to: Notice: Windows 10 Update Causes Date/Time Controls to Not Display Properly Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
