Date/Time: Tue, 14 Jan 2025 23:48:09 +0000
Rithmic Error Connecting
View Count: 912
[2017-05-29 13:32:11]
User357555 - Posts: 5
Hi Support I cant get this to work what can I do to fix it here is the Error Message
Message Log
DTC Client (55) Closed 2017-05-29 13:55:06
Error connecting to Data or Trading service. For help with issue, press the Send for Analysis button on this window 2017-05-29 13:55:06
To prevent further connection attempts, select File 77 Disconnect: 2017-05-29 13:55:
Rithmic Trading Disconnected 2017-05-29 13:55:06
Will reconnect to the server in 2.0 seconds Select File >> Disconnect' to prevent further connection attempts. 2017-05-29 13:55:06
Do I need this or can I do without it Yours Thomas
[2017-05-29 13:36:03]
This is not the complete Message Log.
Provide a copy of the Message Log by following these instructions:
[2017-05-29 16:01:21]
Reading Internal Order ID file. | 2017-05-29 13:51:10
Reading Trade Orders file. | 2017-05-29 13:51:10
Reading Trade Positions file. | 2017-05-29 13:51:10
Listening on UDP port 22903. | 2017-05-29 13:51:10
Software version: 1561 | 2017-05-29 13:51:10
Uses New Spreadsheets | 2017-05-29 13:51:10
Usage end date: 2017-12-27 | 2017-05-29 13:51:10
Enabled for: Advanced Features. | 2017-05-29 13:51:10
Enabled for: Sierra Chart Historical Data Service. | 2017-05-29 13:51:10
Allow Support for Sierra Chart Data Feeds is enabled. | 2017-05-29 13:51:10
Current selected Data/Trading service: Rithmic Trading | 2017-05-29 13:51:10
Chart Update Interval: 500 | 2017-05-29 13:51:10
Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2017-05-29 13:51:10
2017-05-29 13:51:14 Local computer time | 2017-05-29 13:51:10
2017-05-29 12:51:14 Local computer time in UTC | 2017-05-29 13:51:10
2017-05-29 13:51:14 Local computer time in SC Time Zone | 2017-05-29 13:51:10
2017-05-29 12:51:12 Server time in UTC | 2017-05-29 13:51:10
Local computer UTC time and Server UTC time difference: 1 seconds. | 2017-05-29 13:51:10
Program path: C:\SierraChart\ | 2017-05-29 13:51:10
Data Files path: C:\SierraChart\Data\ | 2017-05-29 13:51:10
OS Version Number: 6.1 | 2017-05-29 13:51:10
Locale Setting: C | 2017-05-29 13:51:10
Checking for new symbol settings for service code rim | 2017-05-29 13:51:10
Rithmic Trading | Port for executable: 52411 | 2017-05-29 16:59:58
Listening socket (1388), port 52411 | Closed. | 2017-05-29 16:59:58
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-05-29 16:59:58
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52411 | 2017-05-29 17:00:01
DTC Client (218) | Creating socket. | 2017-05-29 17:00:01
DTC Client (218) | Connecting to IP: 127.0.0.1. | 2017-05-29 17:00:01
Rithmic Trading | Connected to server. | 2017-05-29 17:00:01
Rithmic Trading | Starting socket receive thread. | 2017-05-29 17:00:01
Rithmic Trading | Sending Encoding Request to server | 2017-05-29 17:00:01
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-05-29 17:00:01
Rithmic Trading | Sending logon request message. | 2017-05-29 17:00:01
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-05-29 17:00:01
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-05-29 17:00:01
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-05-29 17:00:01
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-05-29 17:00:03
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-05-29 17:00:03
Rithmic Trading | Received logon response. | 2017-05-29 17:00:03
Rithmic Trading | Server Name: DTC Bridge. | 2017-05-29 17:00:03
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-05-29 17:00:03
Rithmic Trading | Logon error received from server | 2017-05-29 17:00:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-29 17:00:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-29 17:00:03
DTC Client (218) | Initiating close of socket by core. | 2017-05-29 17:00:03
Rithmic Trading | Disconnected. | 2017-05-29 17:00:03
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-29 17:00:03
DTC Client (218) | Shutdown started. Waiting for graceful close. | 2017-05-29 17:00:03
Rithmic Trading | Port for executable: 52422 | 2017-05-29 17:00:05
Listening socket (1384), port 52422 | Closed. | 2017-05-29 17:00:05
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-05-29 17:00:05
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52422 | 2017-05-29 17:00:07
DTC Client (219) | Creating socket. | 2017-05-29 17:00:07
DTC Client (219) | Connecting to IP: 127.0.0.1. | 2017-05-29 17:00:07
DTC Client (219) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-05-29 17:00:08 *
DTC Client (219) | Initiating close of socket by core. | 2017-05-29 17:00:08
DTC Client (219) | Closed. | 2017-05-29 17:00:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-29 17:00:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-29 17:00:08
Rithmic Trading | Disconnected. | 2017-05-29 17:00:08
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-29 17:00:08
Rithmic Trading | Port for executable: 52425 | 2017-05-29 17:00:10
Listening socket (1224), port 52425 | Closed. | 2017-05-29 17:00:10
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-05-29 17:00:10
Date Time Of Last Edit: 2017-05-29 17:39:47
[2017-05-29 17:40:21]
This is the relevant error message.
Refer to:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
