Date/Time: Tue, 14 Jan 2025 23:45:15 +0000
Date Range in file for intraday chart is showing 2007-12-03 and can't be changed manually
View Count: 1699
[2017-05-29 11:53:28]
User234679 - Posts: 5
This is only on GBPUSD symbol. I have tried delete and download data. I have updated to current version. The dates that load start at 2013-07-29 and then gap at 2014-11-06 to today 2017-05-29.
[2017-05-29 13:14:33]
Follow through the instructions here:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data
After this, set the Days to Load in Chart >> Chart Settings to what you require:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html&CAID=#DaysToLoad
Date Time Of Last Edit: 2017-05-29 13:18:21
[2017-05-29 23:37:54]
I followed the steps at these links and the Date range in file from still wont change and the gap is still there.
[2017-05-30 00:23:28]
What is Global Settings >> Data/Trade Service Settings >> Maximum Historical Intraday Days to Download set to? There are two settings. Tell us both of them.
[2017-05-30 02:59:12]
non-tick and 1-tick are both set to 4500.
[2017-05-30 03:33:54]
Go to the GBPUSD chart and select Edit >> Delete All Data and Download from the menu at the top .
Even if you have done this before do this again and select this exact command and do not do this differently.
Date Time Of Last Edit: 2017-05-30 03:34:43
[2017-05-30 09:40:57]
That still did not change the from date and the gap is still there.
[2017-05-30 15:32:00]
Scroll the chart where you see the gap and then provide an image of the chart or Trade DOM, by following these instructions:
Date Time Of Last Edit: 2017-05-30 15:32:20
[2017-05-30 17:28:49]
Alternatively could you please set your telephone number here:
https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo
Let us know when that is done and we can call and use remote assistance to look into this. There should not be any issue with this.
[2017-05-31 10:09:25]
http://www.sierrachart.com/image.php?Image=1496225288890.png
[2017-06-01 02:44:03]
This is simply resolved by re-downloading all of the data for the symbol as previously explained. We could do that for you using remote assistance. It is a very simple procedure, just one command.
As an alternative, just follow the instructions here to delete the entire data file:
Intraday Data Editor: Deleting a Data File
Date Time Of Last Edit: 2017-06-01 02:44:51
