Date/Time: Sat, 26 Apr 2025 09:48:28 +0000
Line chart and overlay
View Count: 813
[2017-05-29 00:15:44] |
User472677 - Posts: 362 |
1. Is the last point in a line chart always updated in real time? The reason I ask is that in your options, the only line chart option is 'line on close'. For example, on a 3 minute line chart, is the LAST point continuously updated in real time or is it updated at the end of 3 minutes only once? 2. In line overay, does the time interval of the original chart matter? For example I have a tick chart of GDX and I want to overlay tick chart of GDXJ. Does the chart of GDXJ that I refer to has to be a tick chart or can it be a 3 minute chart. I a ready have a seperate 3 min GDXJ chart. I do not need to see a separate tick GDXJ chart. 3. To see multiple symbols in a chart to compare, is there a simpler way than having a seperate chart for each symbol and then using overlay study? Some of the competing products allow direct entry of multiple symbols on a chart. |
[2017-05-29 18:56:41] |
1. Yes. it is continuously updated. We are not sure why this is being asked because you can clearly observe that it is. 2. It sounds like in your case it does matter. You will need to use this study: Study/Price Overlay Study 3. No not at this time and please do not ask us further about this. We assume you already know the answer to this anyway. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
