Date/Time: Tue, 14 Jan 2025 23:49:04 +0000
different trading strategies applied on same chart
View Count: 817
[2017-05-28 21:26:16]
User103949 - Posts: 78
If i develop two different strategies for same product, for example es-mini contract, should i compile two dlls and apply them to the same chart at the same time?
I have made one strategy into dll and it is working well. I am not sure adding another strategy on to the same chart will cause any conflict?
[2017-05-29 13:38:16]
Refer to this section here:
Automated Trading Management: Using Multiple Automated Trading Systems at the Same Time
You only need one DLL. They will need to use different Trade Accounts if you want to use them at the same time. So two charts are required.
