Date/Time: Sat, 13 Sep 2025 05:12:29 +0000
CQG with AMP
View Count: 1646
[2017-05-26 05:21:10] |
dtl-saw - Posts: 79 |
I'm currently with AMP trading service and using CQG for data and trading with AMP. With AMP I get the SC software with level 5 for ~$20 but the version of SC that comes from AMP is limited to running only 1 copy at a time and only works with AMP + CQG. If I get a 1 year subscription with SC from you "Sierra" for ~$21 then I can run as many copies of the software I want so that I could have 1 copy running on CQG with AMP and another copy running with TD Ameritrade, etc. So, I see that for about the same money I can a more versatile version of SC to use. I'm posting this message to ask you if I'm missing any fees that may be applied. I think that AMP will charge me the same fees for data as they do now and that level 5 sub for 1 year through SC is ~$21. You mention in an article on this site that using CQG there is $10-$20 data fees and I'm asking you if that refers to the same data fees that AMP is currently charging me using the AMP version of SC or is this some other type of fee from you or CQG that is additional for something like using FIX adapter or whatever. I'm just checking before I sign up with you for a year and want to make sure I'm aware of all fees involved. |
[2017-05-26 06:03:26] |
I'm posting this message to ask you if I'm missing any fees that may be applied. No.You mention in an article on this site that using CQG there is $10-$20 data fees and I'm asking you if that refers to the same data fees that AMP is currently charging me using the AMP version of SC Yes this is correct.
[2017-05-26 12:03:38] |
User204945 - Posts: 2 |
Thanks Also, can you verify that I can run an unlimited number of copies of the SC program simultaneously each possibly using a different datafeed and broker / trading service connection. I haven't been able to verify this since AMP + CQG only allows one instance of the SC running at a time |
[2017-05-26 17:05:21] |
Yes you can do this. But they need to be running on no more than two computers. Refer to: Sierra Chart Purchase and License Information: Licensing / Number of Systems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-26 17:05:45
