Date/Time: Tue, 14 Jan 2025 23:01:42 +0000
Load a Symbol List to Retrieve Historical Data automatically
View Count: 1137
[2017-05-25 13:55:54] |
ilcaa - Posts: 9 |
hello, i am new to SC i want to load a list of Symbols (ETF) that i want SC to automatically retrieve historical data for. Right now I have a quote board with a list of 240 symbols. and as i click a symbol, the chart changes and i can see in the data folder the file is downloaded and present. I want to go 'offline' so I want to download the data for all 240 symbols not click 1x1 to get data.. please advise. thank you! |
[2017-05-25 17:12:37] |
What you need to do is use the Associated Symbol Watch List. Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/SwitchingSymbols.html#DownloadingHistoricalDailyDataForSymbolsList If you want to do this for historical Intraday data, let us know. Although in that case you just need to run a scan: http://www.sierrachart.com/index.php?page=doc/ChartMenu.html#ScanMenuCommands Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
