Date/Time: Tue, 14 Jan 2025 23:16:52 +0000
Problem again with TPO Exclude evening session except last one
View Count: 752
[2017-05-25 13:24:55] |
User968625 - Posts: 260 |
Hello, I have found a problem with this before and today it is also having a problem today. (check my previous posts) clearly the overnight traded in a range 2401.25-2412.50 but the last evening session is showing only 2405.50-2412.50. Even on sierra chart where I show all evening sessions, it shows the right overnight trades and the right range Pls check this one as I thought you fixed it already and it is important Thank you |
[2017-05-25 16:57:34] |
We have verified this has been resolved. We see you are running an older version. Update following the instructions here: http://www.sierrachart.com/index.php?page=doc/SoftwareDownload.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
