Date/Time: Sat, 01 Feb 2025 04:06:01 +0000
Chart Values Window on Multiple Monitors
View Count: 1746
[2017-05-24 20:55:15] |
JayShea - Posts: 92 |
Support People I should know this. If I left-click on a monitor, I'd like the chart windows to solely reflect the monitor being clicked. Right now if I left-click a monitor and then I left-click another monitor, the chart-values window is still in the first monitor, not the one being clicked. I'd like the chart-values window to stay with each monitor and only reflect the issue in that monitor. Many thanks JD |
[2017-05-24 21:54:05] |
This is supported with the "Tool Values Window". Refer to: Chart Drawing Tools: General Tool Settings The setting name is: Save Tool Values Window Position for Each Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-25 14:04:44] |
User439028 - Posts: 2 |
Can you display the Chart Value Window Horizontally?
[2019-06-25 18:14:19] |
John - SC Support - Posts: 37656 |
Not the Chart Values Window, but the Compact Tools Value Window can be displayed either Vertically or Horizontally. Refer to the setting here: Chart Drawing Tools: Horizontal Compact Tool Values Window For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
