Date/Time: Tue, 14 Jan 2025 22:36:18 +0000
2 AutoTrading Systems for the same symbol in Sim mode - how to disable one of them?
View Count: 767
[2017-05-24 17:06:39] |
User718694 - Posts: 25 |
As in the topic. Running 2 different ATSs for the same symbol (2 charts) in SIM mode, how to disable one of them so only the other one takes trades, signals alarms and so on.
[2017-05-24 17:26:28] |
Are these automated trading systems created in ACSIL or do they use the Spreadsheet System for Trading study?
[2017-05-24 18:06:58] |
They use Spreadsheet System for Trading study.
[2017-05-24 18:09:07] |
In this case, set this Sheet cell to 1 on the associated Sheet for the automated trading system you want to disable: https://www.sierrachart.com/index.php?page=doc/SpreadsheetSystemsAlertsAndAutomatedTrading.php#DisableAutoTrading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
