Date/Time: Thu, 16 Jan 2025 16:51:42 +0000
Bid & Ask depth bars study
View Count: 1515
[2017-05-24 15:15:02]
Spinoza - Posts: 62
The Cumulative Difference (Bid-Ask) option of this invaluable study (Historical Market Depth - Last) has been broken for a while. Having read 1550 depth issue I have reverted to version 1549 where it works fine. I should be grateful if you could look at this so I can continue to upgrade to newer versions once fixed.
I think this part of it probably broke when you made some changes to accomodate another user in Bid & Ask Depth Bars
[2017-05-25 05:22:31]
This was resolved and actually was a problem that was created when we tried to solve another insignificant issue they were pointing out:
1550 depth issue
The whole thing was a total annoyance and waste of our time generally. In the end not much really changed.
We need to understand exactly what the problem is with Bid and Ask Depth Bars.
What are all of the Input settings you are using with the Bid and Ask Depth Bars study?
[2017-05-25 09:00:12]
Spinoza - Posts: 62
Calculation Mode: Cumulative Difference (Bid-Ask)
Source Data: Historical Market Depth - Last
Maximum Depth Levels: 4
On version 1549 and earlier these settings give a very good read on order book action on a thin volatile market like DYM17. Later SC versions just show a straightish sloping upward line.
[2017-05-25 10:55:14]
Spinoza - Posts: 62
Should have added Graph Draw Type: Line On Close to the above information.
[2017-05-25 16:52:58]
OK we will test.
[2017-11-16 06:17:59]
Letting you know this has been fixed for several months now.
