Date/Time: Tue, 14 Jan 2025 23:23:46 +0000
Too Much Market Depth. How do I adjust?
View Count: 825
[2017-05-24 14:14:09] |
NG1980 - Posts: 40 |
Suddenly my market depth extends to 50 levels? I used to only see 10 levels which is good because I can still see a balance of depth on the TradeDOM. Is there a way to limit it back to 10 or maybe 16 levels?
[2017-05-24 18:22:49] |
Yes. This is controlled with this setting: https://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#MaxDepthLevelsDisplayed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-25 20:13:31] |
I know I'm just supposed to hit "Thank You" but you guys really are rockstars! Thank you so much!
