Date/Time: Tue, 14 Jan 2025 22:52:21 +0000
Barchart OpenFeed
View Count: 795
[2017-05-24 00:42:55]
Neo - Posts: 198
In another thread you mention:
We should also be switching to the new Barchart OpenFeed in the next couple of months as well
-TVOL-NYSE inconsistency | Post: 117795
What is the difference/ advantage of the new BarChart Openfeed?
[2017-05-24 02:24:45]
From an internal technical perspective it is much better, but from the end-user perspective we really are not sure if it makes any difference. Probably not.
[2017-05-24 02:43:29]
User19165 - Posts: 346
If it helps you get that reconstructed tape going soon, it will be a HUGE difference for the end-user perspective! ;-)
[2017-05-24 03:22:15]
We do not need OpenFeed to do this.
