Date/Time: Tue, 14 Jan 2025 22:31:34 +0000
speed of replay under accurate trading system mode
View Count: 620
[2017-05-23 18:05:00] |
User61576 - Posts: 445 |
i have tick data of the XG continues contract my system is based on the number charts study will there be any difference of the results between speed of 1 and the speed of 30720? |
[2017-05-23 19:04:24] |
There should not be but if there is a problem it would have to something to do with your trading system itself. You can also use a faster speed than that. You should be able to go up to 100000. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
