Date/Time: Tue, 14 Jan 2025 22:41:35 +0000
ordes disapear from orders and positions if NOT in standard replay
View Count: 695
[2017-05-23 17:39:37]
User61576 - Posts: 445
hi
when using standard replay the orders are shown in the orders and positions log
but
if i set the replay to be accurate trading system back test mode, than the orders will be shown as long as they are active but when the trade is done the log will be empty (orders tab)
if i change the speed than it will not affect
pls advice
thanks
Private File
Private File
Private File
[2017-05-24 03:18:31]
Yes this is true and this is documented.
You need to use the Trade Activity Log to look at the order fills instead:
Trade Activity Log
