Date/Time: Tue, 14 Jan 2025 12:05:50 +0000
Detached window ordering
View Count: 663
[2017-05-21 14:23:00] |
User98657 - Posts: 329 |
All of my chart windows are detached. When i click on the SC Globe on my windows toolbar i get a list of all the open windows. I thought i recall seeing an option to order the sequence of those open windows as they appear in the list alphabetically. Can any one point me to that or let me know if i'm mistaken on that option? |
[2017-05-21 20:49:22] |
You can change the order of these detached windows to control the order in which they are opened and subsequently displayed on the taskbar. At least the initial ordering. But not after Sierra Chart is running and the ordering is changed on the taskbar. Refer to: Detaching and Attaching Chart Windows: Internal Ordering of Detached Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-21 20:49:50
