Date/Time: Tue, 14 Jan 2025 12:17:17 +0000
Moving chart up and down when hand is on main chart region
View Count: 1926
[2017-05-20 11:24:19] |
ripsdips - Posts: 143 |
Im in General Settings, General 2. And I have my scroll setting set properly. What do I need to do to have chart go up and down when hand is activated under tools.
[2017-05-20 18:39:55] |
This is explained here: Chart Drawing Tools: Vertical Movement and Scaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
