Date/Time: Tue, 14 Jan 2025 12:07:59 +0000
TPO script for different tickers
View Count: 1000
[2017-05-19 22:19:20]
SurfTrader - Posts: 68
I downloaded this TPO script off the forum, it is for the /ES but I was wondering how I view different tickers on it. It was a struggle to finally open it with the /ES, still havent figured out what I was doing wrong as to why it wouldnt open.
attachmentJIM DALTON (2).cht - Attached On 2017-05-19 22:17:12 UTC - Size: 95.33 KB - 300 views
[2017-05-20 01:46:49]
You just need to change the symbol of the charts within that Chartbook.
Here are instructions:
Changing the Symbol of a Chart: Changing the Symbol of a Chart or Trade DOM Through Chart Settings
[2017-05-20 03:09:09]
Ok I did that and it says 'Downloading Historical Data. Bars may not appear until done', and it never fully loads. Shows the ticker but only pieces if the TPO load.
[2017-05-20 03:09:37]
Says download failed
[2017-05-20 16:36:24]
Did you change the symbol of the chart to ES-201606-GLOBEX?
[2017-05-21 03:28:35]
I'm trying to change it to different ticketed other than es. I've tried amzn and aapl both failed to download.
Do you have live tech support where I can speak to someone?
[2017-05-21 20:52:19]
Yes this is available for an additional cost. Refer to:
https://www.sierrachart.com/index.php?page=doc/support.html#Interactive
Otherwise, we would need to see the Message Log after you have changed the chart to a stock symbol and re-downloaded the data. To re-download the data, go to the chart and select Edit >> Delete All Data and Download.
Provide a copy of the Message Log by following these instructions:
Date Time Of Last Edit: 2017-05-21 20:52:48
