Date/Time: Tue, 14 Jan 2025 12:06:06 +0000
Zooming out TPO chart and viewing past data
View Count: 1178
[2017-05-19 22:13:34] |
SurfTrader - Posts: 68 |
Is there a way to quickly zoom out to take a birds eye view on the TPO chart. Adjusting the scale range just scrunches everything up and makes it unreadable. Also how do you view Data on the TPO further back than a month. That is as far back as my chart goes. |
[2017-05-20 16:37:16] |
1. Reduce the bar spacing in the chart. Refer to: Working With Charts: Changing Bar Spacing 2. Use the Continuous Futures Contract feature: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-20 16:37:50
[2017-05-21 14:57:02] |
Ok thanks. I just need to get used to viewing the TPO I think. How do I draw a price level on the TPO chart and customize it. Name it, change color/width ect. Thanks |
[2017-05-21 20:47:05] |
You need to use the Horizontal Line drawing tool: Chart Drawing Tools: Horizontal Line | Horizontal Ray | Horizonal Line Non-Extended | Vertical Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
