Date/Time: Tue, 14 Jan 2025 11:56:28 +0000
What update interval do you recommend for Trader DOM with Sierra Chart Data Feed?
View Count: 2350
[2017-05-19 20:02:09] |
User772556 - Posts: 21 |
I have i7 processor, 12 gigs of ram. Thanks Date Time Of Last Edit: 2017-05-19 20:02:20
[2017-05-19 22:34:24] |
If you want a fast update you can use about 150 milliseconds. However, make sure you only set this on the Trading DOM itself. Refer to: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-20 00:30:37] |
User19165 - Posts: 346 |
I have a way lower spec machine than yours and I have it set to 100ms for my 1-tick market depth historical chart and my DOM, replicated across 3 markets - Bund, Dax, Stoxx. I have previously had it set to 10ms, also without issue. Just FYI.
