Date/Time: Tue, 14 Jan 2025 12:04:39 +0000
Data Feed
View Count: 741
[2017-05-19 15:43:58] |
User160648 - Posts: 5 |
I have IB,Sierra,and Bracket trader.I get my real-time data feed from Sierra. BT is connected to IB. Data does not flow through to BT. Does Sierra prevent data flow to BT? If so, how do I turn off Sierra data flow?
[2017-05-19 21:04:38] |
. Data does not flow through to BT Yes, this makes sense. What you want is not supported. Does Sierra prevent data flow to BT? No, not at all.However, Bracket Trader could use the Sierra Chart data feeds. Refer to: Data and Trading Communications (DTC) Protocol Server Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
