Date/Time: Tue, 18 Feb 2025 23:00:18 +0000
Spreadsheets
View Count: 1564
[2013-08-23 19:15:15] |
User96105 - Posts: 113 |
Hi can you assist me with spreadsheets please? Can I produce a horizontal line study from a spreadsheet to produce multiple lines? I would like to add text/price labels, colour etc. How can I do that? Thanks |
[2013-08-24 21:46:11] |
vegasfoster - Posts: 444 |
Add the spreadsheet study, starting column K put the formula you want for each line, then go to the Subgraphs tab and check show Name Label and Value Label for each subgraph that would to show this info.
[2013-08-27 01:37:36] |
Refer to the documentation for the Spreadsheet Study here: http://www.sierrachart.com/index.php?l=doc/doc_StudiesSystemsAlerts.php Refer to the documentation for the Subgraph Name and Value labels here: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#NameValueLabels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
