Date/Time: Tue, 14 Jan 2025 12:16:08 +0000
VbP study overlay?
View Count: 888
[2017-05-19 14:21:38] |
User98657 - Posts: 329 |
Is there a way to display a VbP study from a composite chart (daily bars) onto an intraday chart? I thought i could use Study/Price Overlay study, but that's not working for me. This started because i was interested in transferring the peaks and valleys from a composite profile onto my daily chart. From what i can tell, peaks and valleys are only part of the VbP study so i thought i'd overlay that study, but i'm not able to get it to appear on the destination chart. If anyone can point me to documentation on this i'd appreciate it. |
[2017-05-19 15:42:47] |
No, this is not supported and is specifically documented.
