Date/Time: Tue, 14 Jan 2025 12:07:59 +0000
Daily EMA on Intraday Chart
View Count: 826
[2017-05-19 12:38:12] |
lpfin123 - Posts: 59 |
I know, the question has been asked. You were suggesting to overlay the study. My question is more if there is another way. Let's say I follow 20 stocks and on each of my intraday charts, I want to know where the 8EMA is. Does that mean I need to have opened daily chart of all symbols at all time to have access to those daily EMAs? Thank you, just want to be sure before I start this task! |
[2017-05-19 16:09:08] |
Yes this is correct. But the charts can be hidden through Window >>Hide Window.
