Date/Time: Tue, 14 Jan 2025 12:00:38 +0000
Position Displaying On Chart, But Not In DOM
View Count: 1037
[2017-05-18 19:51:28] |
CustomIndicators - Posts: 126 |
I've got an automated trading algorithm going. On a chart, I have turned on both options: Show Order Fills and Show Orders And Position. On that chart, the trades are displaying perfectly. I can see the entry and exit marks on the candles, as well as the amount of each profit or loss. I can also see the line across the screen which marks the entry point. When I open a DOM with the same exact ticker symbol (triple checked that ESM7-CME was on both title bars), the DOM shows Flat. It doesn't show my position at all. This is in Sim mode right now. I would really like to be able to get out of bad trades in an emergency situation. What can I do to get this DOM linked up properly, so that I can kill any bad trades? |
[2017-05-19 04:27:12] |
You need to set the Trading DOM to the same Trade Account: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
