Date/Time: Tue, 14 Jan 2025 12:38:05 +0000
Can SC be optimised to run on multiple threads?
View Count: 1375
[2017-05-18 18:32:49]
michelh - Posts: 159
Hi SC,
If you can please consider multithreading SC that would be fantastic.
I use a large number of charts due to lots of time frames with custom dlls
It is a nuisance running multiple instants and if you could please consider multi-threading the application, I am sure that a lot of your loyal followers would be grateful
thanks
[2017-05-18 19:42:12]
gomifromparis - Posts: 244
You can start multiple instances of SC, it will split the load
[2017-05-18 20:42:29]
Sierra Chart uses multiple threads within each process to the extent it can.
Beyond this is so monumentally complex and detrimental both in known and unknown ways, there is no chance we would get involved with this any further, at least not for years from now. You should not have any expectation beyond what is already available.
Date Time Of Last Edit: 2017-05-18 20:43:03
[2017-05-18 21:09:15]
You mention you are using custom DLLs. So the first thing you should do is focus on improving the efficiency and speed of those custom studies. That is going to give you the most benefit without any complications.
