Date/Time: Tue, 14 Jan 2025 12:53:08 +0000
SC feed limited to one connection? - i pay for two..?
View Count: 747
[2017-05-18 15:48:05]
Cavalry3162 - Posts: 523
Hello SC,
see excerpt from the message log:
SC Data - All Services | Disconnected from the server. | 2017-05-18 09:55:16
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2017-05-18 09:55:16
SC Data - All Services | Using username 1 | 2017-05-18 09:55:19
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2017-05-18 09:55:19
DTC Client (995) | Creating socket. | 2017-05-18 09:55:19
SC Data - All Services | Connected to server. | 2017-05-18 09:55:19
SC Data - All Services | Starting socket receive thread. | 2017-05-18 09:55:19
SC Data - All Services | Sending Encoding Request to server | 2017-05-18 09:55:19
SC Data - All Services | Setting DTC encoding to Binary VLS | 2017-05-18 09:55:19
SC Data - All Services | Sending logon request message. | 2017-05-18 09:55:19
DTC Client (995) | Socket gracefully closed by remote side. | 2017-05-18 09:55:19
DTC Client (995) | Received socket Close event | 2017-05-18 09:55:19
DTC Client (995) | Initiating close of socket by core. | 2017-05-18 09:55:19
DTC Client (995) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-18 09:55:19
DTC Client (995) | Closed. | 2017-05-18 09:55:19
SC Data - All Services | Received logon response. | 2017-05-18 09:55:19
SC Data - All Services | Server Name: SC Real-Time Server. | 2017-05-18 09:55:19
SC Data - All Services | Server protocol version: 7. Client protocol version: 7 | 2017-05-18 09:55:19
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2017-05-18 09:55:19
SC Data - All Services | Disconnected from the server. | 2017-05-18 09:55:19
[2017-05-18 16:01:54]
Make sure you are not using the Sierra Chart Exchange Data Feed from more than two instances of Sierra Chart.
Your account is authorized for two connections.
[2017-05-18 16:15:20]
i am using it only from two instances
[2017-05-18 16:15:59]
or better, i try to use it from two.. works only from 1...
[2017-05-18 16:22:47]
got it to work.. it was a 3rd instance, for whatever reason the "enable support for sc feed" becomes selected..
