Date/Time: Tue, 14 Jan 2025 12:38:39 +0000
Modifying Orders on the Trader DOM
View Count: 654
[2017-05-18 15:20:15] |
User772556 - Posts: 21 |
When I have orders on the trader DOM in order to modify it I have to click and drag them to where I want them to go. Is it possible to just click on the price where I want it to be and have it moved there automatically? This way I dont have to do the dragging. Right now if I click on another spot, it just makes a new order. Lets say I am in a long position and I want to adjust my stop closer. I want to be able to click on the offer column and have the stop moved, without physically having to drag it and without it creating a completely new stop order. Let me know if this is possible. Thanks, |
[2017-05-18 16:03:13] |
No, this is not supported.
