Date/Time: Tue, 14 Jan 2025 12:26:30 +0000
Import export greyed out
View Count: 1210
[2017-05-18 12:42:52] |
grantx - Posts: 244 |
I have some trades selected in the trade activity window but cannot export the data because the option is greyed out. Why is this? From the trade activity window, can I export the 'Trade stats for charts' data? Date Time Of Last Edit: 2017-05-18 16:10:05
[2017-05-18 16:48:18] |
You need to use File >> Save Log As instead. Refer to: http://www.sierrachart.com/index.php?page=doc/TradeActivityLog.php#Saving From the trade activity window, can I export the 'Trade stats for charts' data?
No.
