Date/Time: Tue, 14 Jan 2025 12:53:26 +0000
Double click to adjust drawing
View Count: 774
[2017-05-18 10:38:16]
zzzzz - Posts: 14
Greetings,
I used to be able to select a tool, let's say the horizontal line tool, place a horizontal line, then double click on the line to adjust it. I no longer can do that without selecting the pointer tool first. Once I select the pointer tool, I can double click on the line and adjust it no problem.
Did something change with this feature? Is there an option I haven't been able to find to enable this again?
Thanks for all you do!
[2017-05-18 17:04:17]
There might have been an unexpected change.
We will have to test this. But it is preferable to use the Pointer or Chart Values tool when double-clicking to perform a modification of the drawing.
Date Time Of Last Edit: 2017-05-18 17:04:37
[2017-05-18 23:24:41]
zzzzz - Posts: 14
Thank you.
It certainly is convenient to not have to change back to the pointer tool to do this. Especially when laying down numerous lines when drawing support and resistance.
