Date/Time: Tue, 14 Jan 2025 12:07:11 +0000
Rollover the trade dom window
View Count: 1629
[2017-05-18 00:50:23] |
User375110 - Posts: 28 |
SC: After I have a trade dom set to the way I want it, I know that I can save it by pushing > Menu > save configuration. How can I then save this as the default template so that when I want to load a new symbol, the default template will be as I have already set it and I don't have to change the colors or number font size, etc? Date Time Of Last Edit: 2017-05-18 01:15:04
[2017-05-18 05:49:01] |
Did you want to open a completely new Trading DOM window for a new symbol? Or just change the symbol of an existing Trading DOM? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-18 05:49:22
[2017-05-18 12:29:32] |
SC: You wrote: Did you want to open a completely new Trading DOM window for a new symbol? I want to save a trade dom window as the default. For example, if I have a trade dom window set with the colors and fonts that I want. I want to save it. Then, if I want to open a new trade dom window for a completely different symbol, I select File>Open trade dom and this default has my colors and fonts on it and then all I have to do is select Chart>Chart Settings> Symbol:Find and change to the new symbol. Then select menu and save this configuration under the name I choose. You wrote: Or just change the symbol of an existing Trading DOM? I know how to change a symbol on an existing trading dom. All I have to do is select Chart>Chart Settings>Symbol: Find and change the symbol. |
[2017-05-19 05:21:17] |
What you want to do is duplicate an existing Trading DOM. You need to use this command: Chart Menu: Duplicate Chart (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
