Date/Time: Tue, 14 Jan 2025 12:41:29 +0000
Disable Drawings
View Count: 1148
[2017-05-17 15:19:21] |
User104854 - Posts: 457 |
Hi. Is there a way for me to disable activating the drawings when I click on them on a particular chart? I like that the drawings can be erased or adjusted on any chart but on the one that I use to execute orders I'd prefer that I have a way to deactivate the drawings so that when I click on them nothing happens. Is this possible? Please advise. Thanks. |
[2017-05-17 21:11:51] |
You can lock a drawing: http://www.sierrachart.com/index.php?page=doc/Tools.html#LockingChartDrawings If you are referring to drawings copied to other charts, it is possible to prevent the modification of those drawings. Refer to: http://www.sierrachart.com/index.php?page=doc/Tools.html#ModifyingAndDeletingDrawingCopiedToOtherCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
