Date/Time: Tue, 14 Jan 2025 12:37:40 +0000
ITALIAN STOCKS SYMBOL
View Count: 1005
[2017-05-17 14:57:33]
User422119 - Posts: 2
I've activated the italian stocks quotes in IB, but i can't find the symbol in sierra chart.
For example Intesa Sanpaolo symbol in interactive brokers is -- ISP Intesa Sanpaolo SpA (ISP@BVME)
i've attached the shot.
imageisp.JPG / V - Attached On 2017-05-17 14:56:35 UTC - Size: 146.83 KB - 280 views
[2017-05-17 15:19:19]
You need to use this symbol:
ISP-STK-BVME
Let us know if that works. It should.
[2017-05-17 19:49:22]
Works! Thank you very much.
But the numbers bars do not work, maybe i need to buy the second level book on interactive brokers?
imageisp shot.JPG / V - Attached On 2017-05-17 19:49:17 UTC - Size: 195.84 KB - 245 views
[2017-05-18 05:57:45]
We have added symbol settings for this symbol.
Global Symbol Settings: Update Symbol Settings
After that is done, follow the instructions here to apply them to the chart:
Global Symbol Settings: Update/Apply Symbol Settings to Charts
Also refer to:
Numbers Bars: Adjusting Tick Size For Larger Increment
