Date/Time: Thu, 17 Sep 2026 04:09:04 +0000
Delete user drawings in "LastCallToFunction"
View Count: 2938
[2017-05-17 13:21:46]
T29_Dev1 - Posts: 22
I have a study to draw some graphic elements as user drawn drawings. Study deletes that drawings in "LastCallToFunction" section.
Deleting works fine when I remove the study from chart. But when I do:
1. close chartbook (save all - yes)
2. re-open the chartbook
I can see drawings from previous session.
I attached a simple study to show the issue. If you add this study to a chart and open/close chartbook a couple times, you will see many instances of text.
SCSFExport scsf_delete_user_drawing(SCStudyGraphRef sc)
  int &ln = sc.PersistVars->i1;
  if (sc.SetDefaults)
    sc.GraphName = "Delete User Drawing Test";
    sc.FreeDLL = 1;
    sc.AutoLoop = 1;
    sc.GraphRegion = 0;
    return;
  if(sc.Index == 0)
    if(ln == 0)
      s_UseTool tool;
      tool.AddAsUserDrawnDrawing = 1;
      tool.ChartNumber = sc.ChartNumber;
      tool.DrawingType = DRAWING_TEXT;
      tool.Region = sc.GraphRegion;
      tool.Color = COLOR_RED;
      tool.FontSize = 13;
      tool.TextAlignment = DT_TOP | DT_LEFT;
      tool.UseRelativeVerticalValues = 1;
      tool.BeginDateTime = 2;
      tool.BeginValue = 98.0f;
      tool.Text = SCString().Format("I'm Text - %f", (float)sc.LatestDateTimeForLastBar);
      tool.AddMethod = UTAM_ADD_OR_ADJUST;
      sc.UseTool(tool);
      ln = tool.LineNumber;
  if(sc.LastCallToFunction)
    if(ln != 0)
      sc.DeleteUserDrawnACSDrawing(sc.ChartNumber, ln);
[2017-05-18 06:06:38]
You need to save this structure variable to 0 to prevent the drawings from being saved:
https://www.sierrachart.com/index.php?page=doc/ACSILDrawingTools.html#AllowSaveToChartbook
