Date/Time: Tue, 14 Jan 2025 12:53:08 +0000
Study doesn't paint for foreign exchange contracts
View Count: 759
[2017-05-16 22:56:29] |
User953894 - Posts: 58 |
I used the Color Bars Based on Alert Condition on a chart. It works fine for my usual contracts except it does not work for any of the foreign exchange contracts. To make sure, I used the same chart and the print was correct for ES,CL,GC,ZB,YM,NQ. But none of the currency contracts showed the indication. I also checked this on a forex pair chart and got no print. In the screenshot the stars indicate the condition is met (there are 2 separate instances of the study, one which searches for conditions both above the criteria and the other for both below http://www.sierrachart.com/image.php?Image=149497152565.png |
[2017-05-16 23:04:04] |
Most likely it is because of what is documented here: Study/Chart Alerts And Scanning: The Effect of the Value Format on Identifier Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-17 14:04:42] |
Excellent! Thank you very much! Your response resolves my question. |
