Date/Time: Tue, 14 Jan 2025 12:29:04 +0000
simulation trade is not matching chart
View Count: 729
[2017-05-16 19:10:02]
User61576 - Posts: 445
pls check attached screenshot. the stop (order # 78800) shown as filled @ 12295 but on the chart you can see that it was filled on 12291.5
which is correct?
also what is your recommendation to backtest based on #bars data? what is the max speed?
thanks
Private File
[2017-05-17 21:06:29]
That particular order is a Limit order and you need to look at the Average Fill Price field on the Orders list to see its fill price. Refer to:
http://www.sierrachart.com/index.php?page=doc/TradeStatusWindows.html#OrderFieldDescriptions
We do not understand this question:
The maximum speed depends upon your computer and the method of back testing. Refer to this page:
http://www.sierrachart.com/index.php?page=doc/Backtesting.php
Date Time Of Last Edit: 2017-05-17 21:06:52
