Date/Time: Tue, 14 Jan 2025 12:34:18 +0000
New Instance
View Count: 747
[2017-05-16 17:58:50] |
RonW - Posts: 105 |
Patrick from Infinity claimed in a YouTube video that opening a second instance of Sierra was a more efficient way to access the computer's CPU than having the same number of charts in 1 chartbook. Is this true? Is there a recommended limit to the number of intances? Thanks. |
[2017-05-16 18:49:45] |
Yes this is true. There is no recommended limit, but really two or three instances should be enough. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
