Date/Time: Tue, 14 Jan 2025 12:43:27 +0000
Daily chart : current "open" not set
View Count: 902
[2017-05-16 16:55:44] |
User612903 - Posts: 51 |
Hi, Sometimes in Daily Chart i have the current open which is not set. For example you can look right now with Coca cola (KO), there is no open for the current bar. Is this related to the feed ? Any idea if we can fix this ? Regards |
[2017-05-16 17:35:07] |
We see an open price for the last chart bar for that symbol in a Historical Daily chart. Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-16 17:35:28
[2017-05-16 19:21:49] |
I was going to do the picture so I've done "duplicate chart" and realised on the duplicate chart it was fine. So I restarted Sierra and it's fine now. But what happened still looks like a bug then : - if I was puting the "compact tool values" the "open" entry was non existing Here is what it looked like : (attached) Date Time Of Last Edit: 2017-05-16 19:22:09
KO-daily.png / V - Attached On 2017-05-16 19:21:34 UTC - Size: 117.52 KB - 266 views |
[2017-05-16 19:23:48] |
- if I was puting the "compact tool values" the "open" entry was non existing The attachment does not show this. Clearly an Open price is present. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-17 13:24:38] |
look at the "current bar" on the right. There is no open price that's why there is no body. When I was putting the crosshair on it, i was only having values for low, high, and close. The table was not showing the "open" entry. With my custom dll sc.Open[sc.Index] was set to 0. Regards |
[2017-05-17 21:18:12] |
OK we were not looking at the current bar but the bar that was selected with the Chart Values tool. The complete data should be there including the open.. If not re-download the data with this command: http://www.sierrachart.com/index.php?page=doc/EditMenu.html#DownloadRefreshHistorical Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-17 21:18:32
