Date/Time: Tue, 14 Jan 2025 12:36:34 +0000
v.1557 Number bar Ask/Bid Volume split profile issue
View Count: 829
[2017-05-16 11:11:48] |
NumbersBars - Posts: 141 |
I just updated to pre release 1557. I notice in Number Bar when Background Type is set to Ask/Bid Volume Split Profile, at Ask colummn, profile is colored AND outlined. In previous version 1549, only colored profiles were shown in both Bid and Ask colummn. May I know if this is an issue of the new version or is there any new setting I need to turn off in order to remove the profile outline? I have attached screenshots of both v1549 & 1557 to illustrate the problem. |
Private File Private File |
[2017-05-16 12:41:35] |
Attach a Chartbook containing just this single chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-16 13:32:26] |
Attached is the chartbook with number bar chart. Tested in version 1556, same problem is observed. |
Private File |
[2017-05-16 21:06:57] |
We have fixed this problem. It will be out this evening.
