Date/Time: Tue, 14 Jan 2025 11:50:58 +0000
Historical Chart
View Count: 697
[2017-05-15 17:49:02]
User497973 - Posts: 15
I've downloaded Open, High, Low, Close data from several historical charts (i.e. Edit > "export bar data to text file").
The text file shows a time stamp of 00:00, which I assume it 12am close time for each bar. However, when I try to match the prices to a regular intraday chart (just to double check) the highs/lows/ and close prices don't match up.
Is there a different bar open/close time I should be looking at for historical charts?
Thanks,
DS
[2017-05-15 22:21:46]
You can ignore the time column. We will remove that.
The session times for historical daily bar data is controlled by the exchange.
